Got a Fluidmaster Pro to replace and old ball cock thing with a leaky valve. Trouble is the inlet hole is at the bottom in the corner and quite frankly the fit is terrible and leaks water like crazy even when hand-tight.
The instructions say (in bold) not to use any plumbers putty. I had to remove a large amount of the stuff from the old installation (the stuff is a nightmare to remove). The inside is now relatively smooth for the sealing washer but the unit fits at a bit of an angle when tight and has quite an uneven gap between cistern and "self-centering back nut".
So what's the trick here? Additional rubber seals or something?
