Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
its a corner toilet so can only test when in situ.The donut seemed vey hard not the normal soft type ive seen before. Could i pack plumbers mate on either side of donut?its a closed coupled toilet, is there any mods to get the flush pipe further into the bowl, kind of extending it?I can't believe toilets have changed so little, must be a better solution than a donut considering the volume of water gusshing at any one time
no that wont seal
Best to remove and check nut is tight and replace with a new dognut from plumb center/plumb base e.c.t.
I know a pain but best way.. did you install it if not get plumer back to put it right for free
