I am going to remove a toilet but need to know how about sealing the sewage pipe. A new toilet may be fitted one day so all i was thinking of doing was sealing the hole. Can I just get some sort of cover that goes over the hole to keep the bad smell out?
If you can see the fitting the pipe goes into ( like a t-piece or elbow) then you can pull out the bit of pipe and put in the 4" cap or access eye.if you cant see the fitting then you can get a rubber type cap that goes into the pipe itself, basically just ask for a 4" cap that goes into the pipe itself(the name eludes me..sat night..vodka etc )
You can try B&Q as Im not sure what they stock(I live in Jersey and our B&Q is tiny)
here is the plug that goes into the fitting
