    Dismiss Notice
Toilet seat nut problem!
Discussion in 'Plumbing and Central Heating' started by DanAl, 29 Nov 2019.
  1. DanAl
    DanAl
    4 May 2019
    26
    Thanks Received:
    Country:
    So I'm not sure whether this is an easy problem to fix and I've just missed something or whether this is the result of something not being done properly when the toilet was installed.
    Anyway, our wall hung toilet seat is loose as the bracket shown in the 2nd photo has slipped through the hole in the body of the toilet. I can't figure out how to loosen the bolt, as there's a bracket which touches it, shown in the 1st photo.
    The photos most probably shows this better than my explanation! Any ideas what I need to do here to loosen the nut and pull the bracket out before retightening it please folks?
    [​IMG]
    [​IMG]
  2. Sponsored Links
  3. Madrab
    Madrab
    4 Oct 2012
    8,235
    Thanks Received:
    2,350
    East Renfrewshire
    Country:
    That'll probably tighten from the other side. The nut looks like it is held captive by the bracket.
  4. dilalio
    dilalio
    20 Mar 2009
    7,927
    Thanks Received:
    1,289
    Potters Bar
    Country:
    The other end of that bolt (top side) will have a slotted or Phillips screw head, covered by a decor cap. Remove the seat (usually by an unclipping mechanism), remove the decor cap on the seat post and you can then back off the screw/bolt to better reposition the clamp so it bridges the hole in the pan and is more secured.
    Post some pics from above of the seat raised and the posts and we can help you figure out how to access the screw head.
  5. Mottie
    Mottie
    27 Feb 2017
    18,844
    Thanks Received:
    1,886
    Essexshire
    Country:
    On my one, the post that the toilet seat fits on needs an Allen to tighten it. Loosen it until you can get both sides of the bottom securely on both sides of the hole and then tighten it up.
  6. dilalio
    dilalio
    20 Mar 2009
    7,927
    Thanks Received:
    1,289
    Potters Bar
    Country:
    OK... Or an "Allen key" :rolleyes::LOL::p
  7. Mottie
    Mottie
    27 Feb 2017
    18,844
    Thanks Received:
    1,886
    Essexshire
    Country:
    Doh!
  8. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,085
    Thanks Received:
    2,017
    Hertfordshire
    Country:
    Normally due to the nut sitting on the seat.
    :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
    Andy
  9. DanAl
    DanAl
    4 May 2019
    26
    Thanks Received:
    Country:
    Thanks guys. So with your prompting I found that the seat does unclip, but now I don't know how to remove the flange which has the connector protruding through it shown in the photo, to get to the screw head. [​IMG]
  10. Sponsored Links
  11. Madrab
    Madrab
    4 Oct 2012
    8,235
    Thanks Received:
    2,350
    East Renfrewshire
    Country:
    You just prise up that chrome cap (after a clean :whistle:) and you'll see the screw underneath it. Just remember to line the seat up properly first before re-tightening.
    • Thanks Thanks x 1
  12. DanAl
    DanAl
    4 May 2019
    26
    Thanks Received:
    Country:
    Thanks Madrab, I tried to prise it off, but it feels like it's fastened to something and I didn't want to break it. Should I just go ahead and force it?
  13. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,730
    Thanks Received:
    5,045
    Cheshire
    Country:
    It’s wafer thin. You’re probably levering the base plate not it’s cover.
  14. Madrab
    Madrab
    4 Oct 2012
    8,235
    Thanks Received:
    2,350
    East Renfrewshire
    Country:
    It's a thin metal cover over a piece of plastic, so just try to catch the outside edge of it with a plain screwdriver, it should just pop up.
  15. dilalio
    dilalio
    20 Mar 2009
    7,927
    Thanks Received:
    1,289
    Potters Bar
    Country:
    Blow torch the fecker off! :D
    • Like Like x 1
  16. dilalio
    dilalio
    20 Mar 2009
    7,927
    Thanks Received:
    1,289
    Potters Bar
    Country:
    FFS... the slot to prise it up by is plainly visible in the photo posted! :whistle:
    • Like Like x 1
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
