Hi
My toilet tank refills very slowly. Water supply to the Fluidmaster 400 inlet is of the cold water tank in the loft. There is no flow restrictor in the inlet tube. The whole system is almost new (rubber seals are all OK).
The cold water pipe is 22mm and of that pipe there is a 15mm pipe that supplies the toilet.
My view is that it is the water pressure (coming from the cold water tank in my loft) being too low. Do you think I can connect the toilet to the raising mains?
The problem with the slow refill existed before I had the toilet replaced.
Many thanks for help
Wojtek
Wojtek
