Toilet Waste Connector
14 Mar 2007
Yorkshire
I am fitting a new toilet in a slightly different place in the bathroom. I have just realised that it should have a swan neck connector but this will cause extra problems due to what's underneath.
The 90 deg. connector that I had initially bought will fit on the toilet pipe but because there is not quite enough space for it, it is not at 90 degrees. It is about 15 deg. off vertical.
When I pull the connector off I am having to prise the rubber seal off of the toilet pipe. So my question is do these 90 deg. connectors allow for such a variation from vertical due to the rubber seal or would it be likely to leak?
Thanks for any advice.
they do have some tolerance as stated in the product specs. You could try it and see if it drips as it wont discharge the whole flush onto the floor.
