Toilet waste fitting in the floor.
6 Nov 2013
Sussex
I am renovating a 1950's bungalow.. It has an old toilet where the cistern is on the wall and a pipe joins it to the back of the bowl..
The plumber I had around to quote on the new heating system had a quick look and said the location of the waste pipe in the floor was too far forward for new toilets. He has said a new waste would have to be created in the concrete floor and the driveway dug up outside with a man hole cover installed to connect it to the drainage.. The old hole would also have to be filled in..
This seems like a huge amount of work to replace the old toilet.. Surely this is a common problem in these old houses and there is an easier way to solve the problem?
What is the maximum distance a waste pipe should be from a wall for newer toilets?
Are there any clever connections that would sit the new toilet further back over the waste pipe in the floor?
Thanks..
If you are dealing with a solid concrete floor then I'm afraid he is correct.....the alternatives are a swan neck pan connector (which doubles back on itself for a couple of inches) or packing the new cistern out with a timber structure.
All too common issues these, when the old wash down pans are converted to close couples.
John :)
If you have to create boxing to bring the pan forward, consider making it look intentional by using a concealed cistern in the boxing or a vanity unit
