Toilet waste pipe quite far from wall, what can I do?
28 Nov 2009
Kent
Basically the waste outlet for my loo is in the floor, but it's miles away from the wall as per pic, meaning my loo comes out quite far into the room. From the wall to the centre of the pipe is 30cm!
Now my bathroom is not the largest room in the world - infact it's bloody tiny, so I'd quite like to get a loo which didn't come out into the room quite as far. However with the waste pipe in this position I'm not sure if this is possible??
Any ideas if I can better this without moving the waste pipe, as I don't have the time, money or want to start digging up the floor in the room.
Many thanks in advance!
Mike.
The only way to do this properly is to dig up the floor and move the soil pipe back to wall,this way you will be able to fit a close couple pan and cistern,
Otherwise you could try a ? mark pan connector to get you back a bit further,av a chat with a Plumber
if you dont want to dig up the floor then fit a swan neck pan connector, (as slapper suggested) this will take the pan back about 100mm, back to the wall pan and concealed cistern would work ok.
Think everyones just offering possible alternatives. ffs
1. dig up the floor ffs
2. fit ? mark pan conn' ffcs.
3. fit false wall fffs.
fs
FFS swan neck pan connector and low level wc. cheapest option to gain a few inches. failing that like mr seco said to torrents of abuse, build a stud wall out to take a close coupled.
ffs
This is a swan neck connector (or space saver) as mentioned before but from what I can see in you pic it probably won't make a difference to how far forward your new pan will be. In other words you don't have a choice unless you're prepared to go back on your word and dig out the floor.
just use a bucket s*d the pan connector.
then you can get it right in the corner.
