My pan waste outlet is at an angle to the soil stack. I have put on a standard flexible waste tube with a push fit seal onto the pan but it is not holding and has never sealed properly.
Q. Do I trust my luck with another of these push-fit tubes, or is there a flexible tube with a rubber washer and threaded sleeve and collar that can be screwed tight onto the pan. Or do I need to consider using plumbers mate or a sealant to somehow seal the existing tube around the pan outlet?
