Hi
I have had the trenches dug (825mm deep, 450mm wide) for my extension and the piling guy is coming tomorrow to lay the piles and ring beam. The trenches are in the right positions although a marking out line shows they are not 100% square.
The ground is really poor so the dig out left parts of the trenches wider than 450mm and some parts 500-550mm.
The depth varies in parts of the trench too, from 810mm to 870mm.
Basically, i'll get the walls square within the trenches although some will be closer to the trench edge than others (so the wall will take a slight diagonal along one trench from end to end; does that make sense?). One trench over by 75mm at one end. My logic would say it's near impossible to get a digger to be mm perfect, so am i being pedantic? Is the height or squareness a problem?
I'm constantly worrying about this foundation!
Cheers, Chris
Cheers, Chris
