Hi There, i have a tivoli 1.5 pump feeding my shower, with brand new surrey flange in tank. i get plenty of hot and cold water to the shower mixer however it remains tepid. The pipe feeding it gets nice and hot, if i turn the isolater (screwdriver type in-line) a third of a turn so as to restrict the cold water pressure the hot is fine. My questions are as follows a) is there a valve that is purpose built to reduce pressure in the cold feed ie should i use an tap type valve ? and b) does anybody know if there is usally an adjustment within the mixer unit itself ie can the stops be adjusted to allow more hot and less cold into the mix ? Both feeds are independant and the pressure seems fine at both, however the cold seems to hot muscle the hot so to speak. Any ideas or tips ?
