can you help. my boiler was failing to light and yesterday my engineer (very respected) did 2 things. 1) removed debris from filer where oil leaves tank, and 2) adjusted air intake to reduce amount of air which was blowing out flame. Spent a fair bt of time measuring gases and adjusting both oil pressure and air to get right co2.
all excellent and now very quiet in lighting. BUT this morning wouldnt light at all and when i held hand over air intake flexi tube it was sucking like a vacuum cleaner ( set at just below 4).
any ideas why it should be sucking so hard. I resolved it in short term by resting flexi tube opening against body of the flexi tube so reduces air and boiler lit but obviously i am now not using regulated air intake just luck of the draw. Will i need a new burner or can the air air intake part be replaced on the existing burner? will also call my excellent engineer but it is new years day and cold so not likely to get a visit!
