    Dismiss Notice
Tools for wooden flooring
Discussion in 'Wood / Woodwork / Carpentry' started by oπo, 26 May 2019.
  1. oπo
    oπo
    15 Oct 2018
    4
    Thanks Received:
    Country:
    Just laid some engineered wooden flooring from Kahrs in our study. Results are stunning.
    It took a long time to plan it. Won't change that.
    It took a long time to shift the planks between the room and downstairs, cut them with a jigsaw, take then back and so on. The planks are 2.4m.
    Plan is to continue the rest of our house. I would want to speed up though. I was wondering what would be a good way to cut them upstairs, without making a huge mess/dust etc.
    What tools should I consider buying ?
    Small circular saw with dust extraction ?
    Plunge saw ? Small ?
    I have a Numatic James hoover I could connect to it to extract the dust.
    Thanks for your advice.
    oπo
  2. blup
    blup
    5 Nov 2007
    868
    Thanks Received:
    119
    Country:
  3. foxhole
    foxhole
    14 Mar 2006
    13,583
    Thanks Received:
    1,440
    Kent
    Country:
    I use sliding chop saw for end cuts, much faster than jigsaw as less marking is required , small cheap table saw for long trim cuts for final planks .Then I tell the wife there’s a mess to clean up .
    Or place a large dust sheet outside the room being boarded to cut on .
  4. oπo
    oπo
    15 Oct 2018
    4
    Thanks Received:
    Country:
    Thanks Blup - indeed I use downcut blades. Probably need a a better quality jigsaw though.
    Foxhole - lucky you. I have a small table saw but the room was definitely not square so couldn't cut the final one with the table saw :(
  5. foxhole
    foxhole
    14 Mar 2006
    13,583
    Thanks Received:
    1,440
    Kent
    Country:
    Table saw cuts angles as well as parallel cuts . Only cost me £30 .
  6. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,892
    Thanks Received:
    308
    Country:
    A chop saw, or compound sliding mitre saw, is much more accurate than a jigsaw. A jigsaw isn't the tool for the job, unless you're having to scribe a wavy bit or something
    • Thanks Thanks x 1
    • Like Like x 1
  7. oπo
    oπo
    15 Oct 2018
    4
    Thanks Received:
    Country:
    Thanks Gerald.
    Borrowed a miter saw from a friend. Much faster process indeed. As long as it has good dust extraction everybody happy.
    oπo
  8. Notch7
    Notch7
    15 Sep 2017
    9,158
    Thanks Received:
    797
    Sussex
    Country:
    :ROFLMAO::ROFLMAO::ROFLMAO:
  9. Ian H
    Ian H
    14 Sep 2010
    5,452
    Thanks Received:
    588
    Rochdale
    Country:
    There is a guillotine that cuts wood floor, zero mess.
Loading...
Share This Page
