- Joined
- 27 Jan 2008
- Messages
- 28,399
- Reaction score
- 3,452
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Painted 4 sides of the building, only a problem on the side which got the sun, bubbles formed in the paint. I will guess paint too thick, and a skin had formed before paint under skin had dried, but I was not really painting it thick, so to get any thinner it would need white sprite added, not sure if that will help or hinder, the painting was on bottom three slats, next lot will need scaffolding, so easy to rub down and fix the existing problem, but scaffolding will need removing each day for trains to pass, so really looking for one coat cover on the signal box cladding.
Most of the painting was done before the wood parts were fitted, all done undercover in the running shed, can't use different makes, as heritage colours for GWR. I don't rate the paint, even some 3 weeks after painting, handling the wood, and we find paint on our hands, and we have had it pealing off, in less than a year on platform benches, but others with same paint and same painter (me) have done 5 years without a problem, but for benches we have moved to plastic instead of wood, as that should outlast my lifetime, we are putting angle iron under the plastic to stop it warping.
I had in the past blamed the cold for the paint not setting etc. But it seems also a problem in the heat?
