- Joined
- 27 Jan 2008
- Messages
- 29,940
- Reaction score
- 3,729
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Where I volunteer we have a load of benches for use by the general public, we would pull in the bad ones each winter and repaint, and we had experimented with plastic instead of wood, so no need to repaint, just one done to date, and it is working well, but to use plastic we have to put angle iron underneath, or it will droop over time, so it is a big job to replace with plastic.
This year we could not use the space normally used to repaint in, so we have around 3 benches needing either plastic or repainting.
Using oil based paint, some bits can remain transferable a month after painting, in general the paint is dry in a day or so, but any drips missed etc, can stay wet for a month, when we have painted wood before fitting like with a signal box refurbishing, we have found paint on our hands, two weeks after painting, so to repaint in summer, can't be sure safe to put back in use until a month after last coat.
So my thought is water based paint, which seems to dry faster, to a safe level where it will not transfer, idea is just to do the very bad benches, and over winter will start using plastic again, but the question is, why was water based paint not used before?
I know not as good preserving wood to oil based, but looking at a stop gap, not to last for years. So what is wrong with fast drying water based paint?
