Paint front of house exterior - advice needed!
26 Jan 2009
Bristol
Hi
We had the front of our house re-rendered and painted a few years ago. Despite the guy doing a mist coat and then a couple more coats its faded a lot (gets a lot of sun) and needs tidying up. I was looking to paint it myself but need a bit of advice:
- there are no peeling bits - do I need to sand it/scrape it down or can I just paint over?
- I want to do it as cheaply as possible but appreciate a ladder might not be the best option - I was looking to hire a scaffold tower or something similar (seems cheaper than getting proper scaffolding put up?) and paint off that. Do you think this would be ok?
- I guess I need a big thick roller (and brush to do edges). Any advice on what to use?
Any other help/advice would be great - particularly on how to avoid marks where paint overlaps.
Pete
12 Aug 2010
Glamorgan
Firstly it may be easier for you to work from a tower as opposed to a ladder, providing the paint work is not heavily soiled a brush down with a stiff bristle brush would be fine, not a wire one. Thin your paint approx 5% and you will need around a 3" brush and a 9" medium pile roller.
Dec
12 Aug 2010
Glamorgan
Missed a bit, you will need to keep a wet edge when you are applying your paint so don't stop for cuppa until your finished and avoid painting in hot sunny conditions.
Dec
6 Dec 2005
Devon
.............it sounds like this is a DIY job yes?
Please be very careful when using any ladders or scaffold if you are not experienced.
If the house gets a lot of sun, choose a light, reflective colour, and no, like the other fella said, dont do it in direct sunlight.
If the paint keeps fading, why not consider having an exterior wall coating applied to the house on your behalf, would last a lot longer than paint.!
28 Oct 2005
Because they are a load of expensive tat that is useless?
14 Jan 2011
Hampshire
You have to go with what is the safest, what price do you put on a broken neck?
Pliolite paint is good
