    Dismiss Notice
Top coat
Discussion in 'Decorating and Painting' started by thespecialone, 23 Aug 2019.
  1. thespecialone
    thespecialone
    4 Feb 2007
    45
    Thanks Received:
    Buckinghamshire
    Country:
    What is the longest i can leave top coat before applying the second coat thanks in advance
  2. Sponsored Links
  3. blup
    blup
    5 Nov 2007
    996
    Thanks Received:
    143
    Country:
    Im not sure there's a specific timescale.
    If its emulsion you could lightly sand the existing, and always apply a third coat if the first coat showed through.
    Its probably more a question of how long the paint can / should be kept in the tin, personally i wouldn't leave it more than a few weeks in a tightly sealed container but the pro's on here will be able to advise more definitively.
    Blup
    • Thanks Thanks x 1
  4. sparkwright
    sparkwright
    20 Aug 2009
    7,076
    Thanks Received:
    858
    Dorset
    Country:
    Oil-based gloss will be a problem - a second coat of oil-based gloss needs doing fairly quickly, if not you risk it peeling off in time.
    Personally I wouldn't leave it more than a week, but that's partly because I don't know the actual answer.
    • Thanks Thanks x 1
    • Like Like x 1
  5. thespecialone
    thespecialone
    4 Feb 2007
    45
    Thanks Received:
    Buckinghamshire
    Country:
    the paint being used is dulux ultimate opaque satin
  6. Sponsored Links
  7. opps
    opps
    16 Jun 2006
    3,834
    Thanks Received:
    554
    London
    Country:
    As per Sparkwright's post. I you leave it for a couple of weeks I would recommend giving it a light sand with 180 grit silicon carbide paper to provide a key to aid adhesion.
    • Thanks Thanks x 1
  8. opps
    opps
    16 Jun 2006
    3,834
    Thanks Received:
    554
    London
    Country:
    Sorry thespecialone, I omitted to add that if the paint is still quite soft, drop down to 240 or 320 grit- you don't want to rip the surface.
    Oil based finishes take months to fully cure, where as waterbased paints takes weeks to cure.
    When painting exterior wood work I routinely apply two coats of gloss without sanding in between but I try to make sure that the second coat is applied within a week of the first gloss.
    Please note that I recommended silicone carbide paper, it is very different to aluminium oxide paper. SC paper is typically thinner/more flexible than AO paper and is normally stearate coated which helps to reduce clogging. 180 or 240 AO paper will be more likely to rip a two week old surface.
    Best of luck.
  9. thespecialone
    thespecialone
    4 Feb 2007
    45
    Thanks Received:
    Buckinghamshire
    Country:
    Hi opps thanks for your response the paint is oil based,and it will be almost two week by the time i get the next coat on. The finish is satin will i still need to use 240 grit?
  10. opps
    opps
    16 Jun 2006
    3,834
    Thanks Received:
    554
    London
    Country:
    Two weeks should be fine without needing to sand the older coat of satin. If it were gloss I would recommend sanding.
Loading...
Share This Page
