My ecoair DC18 has given a F0 error. I called Ecoair they said it was either (a) dust (cleaned out and restested still F0), temperature sensor (checked inside could not see any damage to the temperature sensor, PCB seemed fine, I cleaned the green tinge off a sensor) or low refrigerant on the compressor (compressor very hot to touch whilst dehumidifer is running). The dehumidifer was not collecting any moisture in its water tray. So I think the refrigerant level is low.
The dehumidifer does not have a service valve. According to youtube vid (
) a piercing valve (self sealing), a R134a refrigerant recharge canister and pressure gauge is all I need. I have 3 off these dehumidifers and need all 3 and they are all old so worth topping up. Has anyone tried retrofitting a piercing valve and adding R134a refrigerant? Cost is about £20 to top up and the older compressor dehumidifers were better.
