Torbeck toilet valve
4 Jan 2009
Herefordshire
Has anyone fitted one of these ?
Shouldn't there be a bigger hole here to allow the tit to stick out and then be pressed in by the float arm.
Is this manufactured wrong or does it work off air pressure ?
I've used them for about 20 years, they are extremely quiet (sometime you get one that buzzes as it shuts, email the manufacturers and they will post you a modified part)
they are quite prone to grid or scale, in which case you dismantle and wash in clean water. I have only ever had that happen after working on the supply pipe or cold tank. When fitting one, let the pipe gush for a minute or so first to wash out any loose particles. There is a tiny stainless pin that goes through the white grommet in the black diaphragm. You will need a torch to see it.
It is often said that the newer Fluidmasters are more reliable.
Thanks for the reply. This one has a filter in the stem.
Ironically I'm fitting this one to replace a very noisy valve.
I think the metal bit has been replaced with plastic
It's an equilibrium type valve...whatever you do don't start drilling holes in them.
