A good friend of mine is having leaking problems with his garage extension.
After looking at it, i quickly noticed the pitch was far to shallow to accomodate the tiles on it. It`s around 10 degrees.
After looking at various solutions, hes decided he wants to put a built up flat roof onto it.
I`ve done a bit of flat roofing in the past, but it was years ago (my 1st roofing firm if i remember) so i`m no expert, im just trying to get some advice for him. My question is, whats the correct way to use torch on felt onto a wooden base.
can you "tack" on an underlay as the 1st layer, then torch onto that with the top 2 layers? If so, can the torch on felt used for the top layers be used for the underlay?
