- Joined
- 19 Jan 2024
- Messages
- 61
- Reaction score
- 6
- Country
I've done a load of boxing in of pipes in my hallway and it all needs jointing and taping. It's not large areas, but some of the joints are 2.4m long and maybe 15cm wide, but mostly smaller bits. I've already got the paper tape, and I have got a 5kg bag of Toupret interior filler, would there be any issues using this for the jointing and taping? Other option is to buy a bag of Toupret joint skim and fill, so if I go that route, I wanted to ask some questions first.
Some of the walls that will be taped have a vinyl silk paint on. Would it be ok so roller some Gardz on to allow it to stick better, or is sanding it to remove the sheen a better option? Already got the gardz from the last round of decorating. I've got PVA somewhere too, if that's a better bet.
Does Toupret joint, skim and fill set hard like plaster, or does is it softer like easifill? Had a lot of issues with easifill, so want to avoid that.
Does Toupret joint skim and fill crack if close to radiator pipes?
Thanks.
Thanks.
