TOWEL RADIATOR HOT AT TOP, COLD AT BOTTOM RETURN
13 Jan 2010
i Have just installed a towel radiator,
feed is at top and flow return is at bottom.
top is geting nice and hot, and cold at bottom any ideas??
the top feed comes straight from ceiling, and the flow return comes from ceiling and enters the bottom of the rad.
i have bleed the radiator, and tried balancing, ie shutting off all rads but this one.
any ideas
Could be a possible air lock in the return pipe in the loft....can u crack open a joint in the loft on the return pipe above th etowel rail?
Seems a strange way you have decided to pipe up this towel rail....Is it a dropper system/concrete floors?
Are both feed and return pipes entering and exiting at the bottom of the rad ?
any ideas
