hi everyone im in the middle of refitting my bathroom and decided I wanted to change the current radiator. my question is im looking at fitting a set of 60mm rigid tails to bring the pipes to the connection on the rad then adding a 90 degree elbow to take it to the rad then into the rad insert a smaller tail to connect it together ill be using compression fittings would this work as Im unable to move the pipe work under the floor
