Towel Radiator Valve Leak
23 Jun 2014
Staffordshire
Got this leak on one side, shut it off and then the other side started doing it!
Whats the likely cause? They are already as tight as i can get them
Looks like it has a gland that needs re packing. It's a type of seal that stops water from leaking up the spindle. I would replace the valves ,but it's worth trying to re pack first.
I'd like to replace the valves to be sure but I assume there is a lot of work beforehand to ensure water isnt spraying all over the place whilst they are changed?
Hot water is from a cylinder in our home.
The water in your hot water cylinder has nothing to do with the water in your radiators / central heating system.
Before attempting to remove a radiator valve for replacement you would be wise to drain the heating systems water out.
Ok, so boiler off, drain system, same as you would with a combi basically?
Is your heating system sealed / pressurised ,or fed from a small tank in the loft ( feed and expansion cistern, F&E ) ?
Before draining down close the water supply to the F&E. Then check its cleanliness. If needed clean out any crud / clean it. You don't want anything in there to get into the system during draining. Latch motorised valve/s to manually open position. Then drain out.
