TOWEL RADS
14 Dec 2008
Birmingham
I have finally had a new pcb board fitted to my potterton suprima50 boiler after suffering lock-outs for a few months. Everything seems to be fine but i am a little concerned as the towel radiators are still running hot even though i have turned the c/h off at the box downstairs, i have been told it's due to it being direct off the h/w, is this normal?
Yes it is common to have bathroom rads/towel rails piped into hot water circuit. Keeps your towels warm and dry during the summer when the heating is off.
Thanks,
It just seems like the boiler is constantly firing up, and the pump is always on which i presume is down to the towel rads being fed, my h/w tank thermostat is set to 60/70 degrees but the towel rads get scorching hot, could i have a thermostat problem, it is a honeywell(from memory) square type box fixed to the side
Does the boiler stop firing when you turn off the HW at the programmer?
Yes, once it programs to go off, everything is fine and boiler goes off, it's just the continuous firing up when the h/w is programmed on, i thought it may be because the pump is sending water through the towel rads continuously, and like i say the water gets scolding hot even tho temp is set fairly low at 60/70 on cylinder
