I've in the process of building a stud wall to seperate my ensuite from the main bedroom.
Onto this stud wall will be mounted a towel rail, my builders put a triple joist in where the stud wall is going, i've screwed the sole plate onto the top of this, i've also added extra noggins to take the towel rail.
My question now is running the pipes, I could run the pipes straight down from the towel rail and through the floor, but that would be quite ugly, i'd like to take the pipes straight into the wall, but for that to work, I think i'd have to run the pipes up the wall, into the loft, across to a wall on the other side where the radiator will go, and run them down vertically behind the plasterboard, this seems a bit messy, is there any alternative?
If I do have to run them in the loft etc.. would running them in 10mm hep2 be ok? i
