    Dismiss Notice
Traditional looking replacement radiator
Discussion in 'Plumbing and Central Heating' started by jtmk, 5 Jun 2018.
Tags:
  1. jtmk
    jtmk
    16 Aug 2010
    80
    Thanks Received:
    2
    Buckinghamshire
    Country:
    Hi, I need to replace a 600 x 900 K2 double panel double convector radiator and the missus wants a traditional looking column radiator. I can't find anything with those dimensions. Any suggestions?
  2. Combicert
    Combicert
    29 May 2018
    109
    Thanks Received:
    20
    Country:
    Get a different size...?
  3. Hot&Cold
    Hot&Cold
    16 Jun 2017
    1,496
    Thanks Received:
    263
    Country:
    600 high is standard,900 long could be available but may need a compromise =/- 80mm
    The pipes will need altering anyway to accommodate the new rad connection distance to the wall,also consider the heat output difference between a column and a proper radiator.
    decent columns of your size will be around £400+
    be cheaper and less trouble to buy your missus a new hand bag ;)
  4. jtmk
    jtmk
    16 Aug 2010
    80
    Thanks Received:
    2
    Buckinghamshire
    Country:
    Thanks for help Old&Cold...unfortunately I've already removed the old radiator so a handbag's not going to keep my son's room warm next Winter unless I set fire to it!
    I went for this in the end for £199 from Soak.com:
    [​IMG]
  5. muggles
    muggles
    28 Oct 2005
    10,528
    Thanks Received:
    2,005
    Oxfordshire
    Country:
    Hope you've either ordered the feet to go with it or you have a good solid wall to hang it off -- those are properly heavy and the brackets are totally unsuitable for plasterboard walls including dot and dab
  6. jtmk
    jtmk
    16 Aug 2010
    80
    Thanks Received:
    2
    Buckinghamshire
    Country:
  7. muggles
    muggles
    28 Oct 2005
    10,528
    Thanks Received:
    2,005
    Oxfordshire
    Country:
  8. Hot&Cold
    Hot&Cold
    16 Jun 2017
    1,496
    Thanks Received:
    263
    Country:
    As what muggles has mentioned ^ re gripit.
    Your column rad will require decent wall fixings,if your wall is a plasterboard partition consider using snap toggler (m6) see video for toggler & gripit comparison (near end of video)
    if the wall is not a plasterboard partition then other fixings will be required.
    The plasterboard needs to be in good condition,correctly attached to vertical supports and plastered.Remember the column rad will weigh 3 stone +
    happy plumbing :cool:
  9. jtmk
    jtmk
    16 Aug 2010
    80
    Thanks Received:
    2
    Buckinghamshire
    Country:
    Sorry for the delay but just wanted to thank you for your advice. I ordered the feet for the radiator and all now installed with no worries of it coming off the wall now. Thanks for the advice.
    Cheers
    JT
    • Thanks Thanks x 1
  10. muggles
    muggles
    28 Oct 2005
    10,528
    Thanks Received:
    2,005
    Oxfordshire
    Country:
    Thanks for the update - always good to get feedback and hear of good outcomes :)
    • Thanks Thanks x 1
Loading...
Share This Page
