- Joined
- 31 Mar 2012
- Messages
- 58
- Reaction score
- 3
- Country
I've been having problems with the lights on a small trailer - other trailers work fine so my socket is okay.
Indicators and fog work fine.
Bulbs tested with 12v work on both contacts, for side and brakes and side+brake together being respectively brighter or dimmer.
The contacts are all clean and rust free, when checking with a multimeter both tabs work to produce ~12v (brakes when pedal is pressed obviously).
The problem seems to be I can only get the side light portion working, or if I force it in against the keyed nubs - the brake lights. Both positive voltage tabs are contacting tight. Even got new fancy LED bulbs which do the same.
Any ideas?
Any ideas?
