Trap unblocker?
10 Apr 2004
Arising from this topic over in electrics, can anyone tell me the purpose of this setup?
When the red knob is twisted, mains pressure cold water goes through the trap. Is this purely a device for unblocking? Seems a good idea if a little odd - certainly never seen it before?
Certainly never seen this set up before. What you have here is a prv with its dicharge connected to the trap. Is it on the hot or cold or heating pipe?
Do you have a mains unvented hw cylinder or a system heating boiler?
If so it could be the safety for one of these. If not perhaps it is a 'drain unblocker' :shock: :?
Drain unblocker..... :lol: :lol: be handy if it was :wink:
What you have there is definately a PRV, Looks like its from a point of use instantanious water heater.
Not an unusual set up, fairly standard :wink:
I second that :!:
Is there a pressure reducing valve under there somewhere as well :?:
OK I'm blonde but guessing PRV = Pressure Release Valve?
Instantaneous water heater is spot on, as ChrisR pointed out a picture showing the whole thing is posted in the original topic over in electrics.
So what does the valve actually do / supposed to do? All I've found is that you twist the red knob, it blasts a jet of water through the U-bend! I'm failing to see how it has anything to do with the heater as this set-up is in the cold supply pipe before it ever gets to that!
The PRV should only operate (automatically) if the water heater pressure exceeds 6 bar. It should discharge externally via a copper discharge pipe. The set up you have is illegal (water regulations) and might cause water waste and contamination of the mains water supply.
is that not a pressure relief valve? as opposed to reducing?
