Treating cracked ceilings when re-painting
9 Jan 2020
My old house has cracks in quite a few ceilings, typically 1mm or less - historic movement typically it's an old house. Japped hairline cracks but just too big for regular paint to reliably fill, and too small for regular filler.
I figured before repainting these rooms, I would like to have a go at the cracks with some product which is over-paintable. Google shows me a couple of options crack-filling paint and micro-filler, but I'd love some real-world experiences.
I'm aware it's not guaranteed but it seems worth a go for the small effort.
Are they lath and plaster ceilings?
If you push the cracks can you see any movement?
I am a decorator. Providing that there isn't too much movement, I open the gap slightly. Then I vacuum the gap out and then brush in PVA. On occasion, it can lock the plaster together. I then push Toupret Flex and Fill into the gap and remove any excess. It is like a caulk with tiny fibres in it. It will shrink back. I then follow it up with a lightweight filler such as Toupret RedLite, or Red Devil OneTime. Both fillers are very soft so use 150-180g paper. On the upside, the dust will not become statically charged and cling to everything (unlike powder based fillers).
Interesting, thanks. I don't know for sure about all but at least some of them are lathes, there are original ornate covings.
how wide do you want the gap to be ideally?
Another method, which I have seen done and works well is to open up the cracks, make holes along the cracks and squirt in low expanding foam. Wait for it to cure. Cut off excess, fill, sand etc. No more opening of said cracks.
I often use foam to fill gaps. It is great for deep gaps but if the gap is dynamic and subject to movement, the foam will (probably) not lock it in place.
It works really well for cracks in dot and dab plasterboard. The holes either side of the plasterboard is great for eliminating bounce.
I have seen videos of people using it to reinforce lath and plaster from above but you need to lift the floorboards, vacuum away the old dust and then mist it with water to help the adhesion.
pretty cool. I have some lower-enpansion foam (Soudal genius gun) I was going to use for skirting-board gaps, reckon that would do the trick to avoid opening a whole extra tube just for a few quick blobs?
2-3mm should be fine.
If the house is Victorian, the cornice may have been run in situ. The easiest way to tell is to look at the corners. If part of curve is set further back than the plaster, it was probably run in situ. Or at least, that is what I had been told. To be honest, I have never fact checked it.
Sure, other than dot and dab plasterboard, it is great for skim coats over a plaster base, but the OP seems to have a lath and plaster ceiling. In the two first scenarios, the foam has something to expand against (and helps to lock things in place).
Expanding foam is great stuff, I also use it to eliminate bounce in stair strings. Unfortunately, I don't think it will help in the OP's case.
If the OP does decides to drill holes, on the balance of probability, he will hit a wooden lath. As he squirts in the foam into the drilled holes it will simply shoot over the top of the laths and will not stick to anything because the tops of the laths will (probably) be covered in dust.
