Trevi shower temperature problems
16 Nov 2011
Birmingham
I have a trevi cvt shower and am having issues with temp
Here's the issue, couldn't get temp hot enough for a decent shower and it pulses hot then cold, so far I have tried......
Bleeding all system to get air out
Recalibrating the temp valve
Removed thermostatic mixing valve to rule out any blockages
I did however notice that when I flushed the toilet the water temp increased in shower so I turned the cold water pressure down to the house and that has helped with the temperature in the shower however water pressure upstairs is now pretty low.....
The only thing I haven't tried is replacing the thermostatic mixing valve due to manufacturer saying they rarely fail and they are £100.
Any advice would be much appreciated
James
