Triple glazing into double glazing unit
10 Apr 2021
Is it possible to put a triple glazing unit into a double glazing unit and use smaller beading ?
If you know the manufacturer of windows then contact them and ask. I looked at this myself some years ago.
Manufacturers stamp is on the frames somewhere.
It's more common to fit secondary system to prevent noise which is what I done.
On paper to answer I think you can however. It's the weight of the glass and if the frames can take it.
Also the cost of glasse is high and you have to factor in breaking a unit while fitting.
Alas the company is defunct and the unit is 13 years old.
Even if you knew the make of the profile it would depend whether the profile maker/extruder made a slimmer bead for triple glazing
