Triton AS2000XT start/stop switch not working
25 May 2007
London
Tonight, I found the start stop switch doesn't turn off the water, The water stops when I switch off the mains.
With the switch in the stop position, the pump goes, when I press the switch to start it, the pump slows down slightly.
With the switch in either position I can vary the speed.
Any ideas please.
Your post is a bit confusing.
Your water flow keeps running when the stop/start button is in the stop position, But water flow stops when you isolate the mains power.
Does the pump stop when you have the stop/start button in the stop position ? or does the pump keep running ?
The pump runs when the stop/start is on or off.
With the mains supply on, & the start/stop in the stop position the pump runs, , if I then push the switch to start, the pump slows down slightly.
Water come out ok in both positions.
Isolating it, stops the pump completely. :( :( :( :(
Congratulations on buying one of the worse made and least reliable showers made by a firm with the worst customer service!
Buy cheap and get cheap?
Faulty switch?
Faulty switch?
I'll check continuity of the switch tomorrow. It's lasted 5 years.
What makes do you recommend?
Faulty switch?
Well took the cover off, high resistance, sprayed it with contact cleaner. Now seems ok, it's only a temp fix, but there's no point in replacing it as its 5 years old. Hopefully it will last until something else goes wrong & I will get a new shower.
Faulty switch?
Well an update for anyone interested, problem has come back, ordered a new switch, (well complete cover) from Amazon (shower doctor)
