Hi all, I have got a 10.5kw triton aspirante topaz thermostatic shower which i beleive is the same as a topaz T100SI. Recently I have been having the following intermittent fault and as its out of warranty I was hoping someone can help:
flow/pressure from head drops dramatically and at the same time the temperature will not go above 40-42 degrees. Turning the temperature dial makes no difference to temp or flow.
I have checked the filters and scale traps which are clear.
It sometimes goes back to normal whilst showering without touching anything, water pressure in the house is fine, and I noticed that when U switch from economy to full the solenoid is not as audible as when you go from full to economy or cold.
Any ideas what it could be? Possible solenoid???
