Hello
Our triton Spellbind had some unstable temperature and flow. Now flow is stable and temperature is constant, but not heated at all. Continuity test shows that TCO is open circuit, so it seems that TCO has failed.
As replacement there are two options: TCO switch or heater can assembly with TCO. The former is £22 later is £100.
Could you please advise if it is possible/effective to replace just the switch or the entire heater can assembly have to be replaced?
Thank you!!
Timmey.
Thank you!!
Timmey.
