My boss has asked me to draw up plans of one of our buildings. It's located on an acute corner, so the overall building's roughly V-shaped and inside there's scarcely a right angle around. Drawing the plans is giving me real trouble.
I'm working on mm graph paper at 1:50 scale, measuring to the nearest cm and drawing to the nearest mm on the page / 5 cm in the room.
I've tried measuring diagonals and using trig to get the angles, and I've tried measuring the angles of the walls directly using a folding rule to transfer them to the page, but either way I find that if I measure and draw all but one of the walls, the last one doesn't match up, usually with misalignments or length mismatches of about foot.
Other than just fudging it (which I could do because the plans are wanted to mark call points and so on for the fire safety people, not for any actual building work), what should I do to measure these rooms without getting this sort of error?
