TRV on the wrong side. Oops
23 Sep 2023
Western Sahara
It was very hard to tell what was the flow in or the flow out side by looking at my radiators. Well, it seems at least on one radiator I fitted the new TRV on the flow-out end rather than the flow-in lock shield end. Is it a big deal or not, generally speaking? Be a pain to have to do the whole thing again. These are upstairs radiators if that's of any help for small rooms. Thanks
I think the new TRVs work in both directions so I don't think you'll have a problem, but I'm not a heating engineer so hopefully someone who is will advise.
Some TRV can be fitted on the flow, or return, though better on the flow generally.
Problem you might find, is - when they at the point of shutting down, they set up a vibration/noise.
@triangularmonkey - can you tell us exactly which trv you used or post a photo of the valve body? Or have a look at the valve body and see if there’s 2 arrows on it - if yes, then it’s bi-directional and won’t matter.
Hi this is the one. I think I'm alright...
Yep, as per @terryplumb, it’s fine and no issue. It’s bi-directional.
