I had my boiler serviced this week and at the same time I asked the engineer to fix a thermostatic radiator valve on one of my radiators. It had previously not been fixed properly meaning that the radiator was always on the highest setting which wasn't a big problem for me. However, now that the valve functions properly in terms of being able to turn it etc I have a problem with the radiator staying hot.
When I first put the heating on the radiator gets hot - but after an hour or so it's stone cold even if I adjust the TRV or the main thermostat temperature. I've tried it with other radiators in the house on and off but still get the same issue. I can only get that radiator hot again by turning off the heating, waiting for everything else to cool down and than turning it back on again.
Is this just a dodgy TRV? It seems that maybe the pin gets jammed in when the radiator is hot enough but isn't getting released again to get more hot water until the whole system cools down. That's my inexpert thoughts but would be good to hear if anybody knows what is likely to be the problem.
