Trv replacement
  • Thread starter Thread starter Od
  • Start date Start date
Od
23 Oct 2008
Avon
I've combi heating system and need to change a trv, can i do this by creating a vacuum?
cheers
Od
YEAH . depending on boiler turn the isolating valves under the boiler off or screw down the cap on the auto airvent.
tHEN let the pressure go either at a draincock or out of a air bleed on radiator
Cool - it a worcester 24cdi, does this change things?
cheers
Od
cheers
Od
May do when you come to repressure and the fill valve is blocked with grud.
Do not touch the isolating valves on this boiler.
