- Joined
- 7 Mar 2017
- Messages
- 1
- Reaction score
- 0
- Country
Hi all, new here.
Am getting radiator covers so the little ones (2 1yo twins) don't burn themselves on the radiators when hot.
The original installer of the TRVs put them at low level and horizontally instead of the recommended vertical orientation at this level, but on a positive spin this means that I should be able to cut a hole in the side of the covers, stick the TRV out the side and they should then regulate to the room temp and not the heat that will build up inside the cover.
I have seen the remote sensor capillary TRVs for using ideally, but I don't think this is needed if I have the TRVs sticking out the side especially with the extra cost.
Any other tips or tricks for this?
