- Joined
- 25 Jan 2011
- Messages
- 3
- Reaction score
- 0
- Country
I really hope you guys can help me They built my system and even they don't know how it works.
I will try to give as much info as I can.
Boiler is a Kazis SUN (25-81 kW) running on heating diesel, Link here:
http://www.kazis.gr/articles_list.asp?e_lang_id=1&e_cat_serial=001001002002001&e_cat_id=134
The Boiler is connected to a Controlli Kx436 Climatic controller link here: http://www.controlli.org/admin/php_docs/documenti_prodotti/Kx436_DBL127E.pdf which in turn also controls solar panels that provide hot water
I see that the valves open and close from the (solar water and boiler water)
Here is where I get confused:
1 The boiler has 2 thermostats on it, one is the boiler thermostat and the other is the system circulation thermostat.
Can anone explain what they both do? and an appoximation of what they should be set to?
2. Why does my boiler run during hours when hot water should be provided by the solar panals
Please, please help...
