I'm in the process of replacing my kitchen sink. Unfortunately the previous owner of the house was a bit of a bodger, and he didn't bother with things like isolators, which means, in order to replace the tap, I have to turn off the supply to the entire house. Obviously, as I replace the sink / tap, I will be adding isolators, but for now, I have a question about turning off the supply. I tried the main valve under the sink but it's totally jammed. I had a bad experience with one of these before, when I tried to force it, so I went out and turned off the water in the street. I also closed the valve between the cold tank in the loft and the hot water cylinder in the airing cupboard. To my surprise the water still flower, albeit very slowly, from taps in the kitchen, utility room and bathroom. It still ran too quickly to allow me to work on the pipes and install the isolators, so I gave up.
Having considered it I now think I know what was happening, and have a couple of questions.
Presumably, with the external feed shut off, the water which was coming out of the cold tap in the kitchen was the pipework draining. I'm not sure how much stuff is fed from the mains, and how much from the loft tank, but it seems reasonable to assume the cold water taps in the kitchen and utility, as well as the boiler, are fed that way. The cold water tank in the loft is fed by a ball cock, so presumably it can't be the cold water tank itself draining back down to the kitchen tap? The cold tap in the kitchen is definitely fed off the mains supply. I can trace the pipework very clearly, but it soon disappears from view and it's not clear where it goes next.
Secondly, the hot water continued to run very slowly even with the value between the tanks shut. I've read that back-pressure should hold the water in the tank, but even then you can get a little bit of flow. Is this what was happening? If I need the flow to stop completely for this work then could/should I drain the hot water tank entirely?
Expert opinions gratefully received.
