Recently moved into our house, and after removing wallpaper & lining paper discovered the kitchen serving hatch is only covered with plasterboard. Not bricked up.
- would we require planning permission to install a door way in place?
Hatch is wide enough - over 100cm all the plastered over frame looks to be, opening (going off the perfectly flat board) 3ft.
Would it be a case of putting in a lintle and door frame underneath?
Edit: just to add, im only after a bit of advice on what would be required. I won't be undertaking the work myself, with it being a structural wall id be approaching a builder to do the work.
