Hi
I'm sure that the problem did not exist when I first moved in and has certainly getting worse over the last few months. I've searched the internet and I can't find an answer.
The Fluidmaster system ( Diagram Here and I think here ) is about 6 years old and is on the top floor (3/3). The valve body leaks when a cold or hot tap is turned on. This causes the water level to rise above the maximum level of the overpipe, causing a waste of water, higher water bills and annoyance
The system works perfectly at any other time.
6 months ago, a handyman from the lettings agency said it was to do with the pressure in the water supply and that nothing could be done. However as the problem is getting worse, I would consider that wear is a problem - perhaps the valve.
Before I approach the agency I need to be armed with a clear understanding of what the problem is so they can fix it. Without it I'm back to the handyman's response...and nothing will be done
Can someone give me some guidance for what I imagine is a unusual problem?
With thanks
Joe
With thanks
Joe
