I have had problems for several months with my pressure actuated whole house pump running for a couple of seconds regularly through the night. I have traced the cause to be the toilet cisterns (2) dripping regularly although the valves should be closed. My plumber tells me that they all do this until the correct water level is reached. But this goes on through the night and is most annoying. I have had both valve systems (ball, valve and bottom entry piping) replaced but it has made no difference unless I hold the ball valve down for a minute or two when the cistern appears to be full which cures that problem until one of the toilets is flushed again. Another plumber advises me to switch to a Fluidmaster valve but there is not room for this at the side of the siphon. Any thoughts greatly appreciated.
