Our TV in the living room is connected to the aerial on the roof, but the TV in the bedroom isn't, it's using an indoor aerial, which has a horrible reception.
Is there a way i can connect this TV to the aerial outside ?
Yes, the difficulty comes from where the cable for the TV in the lounge runs. Other factors notwithstanding, you need to buy a coax splitter, locate the splitter somewhere convenient, then run one cable from the splitter to the TV in the lounge, and one to the bedroom. Or you could buy a muliplex distribution system. How easy it is to do really depends on the cable location.
