Two radiators, both leaking from same point.
30 Oct 2008
West Midlands
Earlier this year we had to shut off our main kitchen raiator as it had started leaking; the leak in question was from the bottom of the radiator, partly underneath and more or less in the middle. Inconvenient but still...
This week we've had another radiator go in exactly the same way, it has started leaking from the same place and the same way - ie bottom-middle of the radiator and spraying as if there was a a pin hole in the raditator itself.
Now, conventional wisdom would suggest something like the radiators in question being hit in a consistent manner such as being hit with the vaccuum cleaner but this doesn't seem likely given their position. The radiators look like they are of different manufacturers and of different ages so I'm ruling out a faulty batch from one manufacturer. Also, the central heating system runs around 2.0Bar so I'm also ruling out excessive pressure in the system.
The only thing that we can see that separates these two radiators from the other radiators in the house is their age; all of the radiators are > 15 years old. The radiators that have leaked are both less than 10 years old.
Anyone got any thoughts on this?
Sadie.
if you have an open vent system, they are probably just completely rotted through
"open vent system"..? sorry, not well up on terminology.
The council installed a baxi back boiler >10 years ago (probably closer to 20) which was replaced by a Vaillant condensing Combi in April this year.
Straight after the boiler was replaced, the first radiator started leaking and earlier this week, the second started.
I should state however that the second radiator was only switched on last week (it had been left off since the new boiler was installed as we didn't think we'd be using it), so in all probability if this had been left on when the boiler was replaced then both radiators would have gone together.
Sadie.
Just replace the rads. New boiler uses higher water pressure so finds any weak points.
