Two way switch with 2 core and earth??
12 Mar 2002
In our living room, I've got a double 2 way switch where each switch is wired in with two core and earth cable. Fine, no problem there.
However, I want one of the switches to act as a two way switch with another switch at the top of our staircase. Now, I know I'm going to have a real job replacing the two core + earth cable with three core + earth because it runs all over the house. Is there anything I can do to achieve this 2 way switch setup??
Many thanks in advance, Chris
No. you were right the first time, you'll need to use 3+E
I would agree with the above post, you will need to run a 3 core and eart from the existing switch (downstairs) to the new position (upstairs?)
____________
D.J
