S
Stapler
Hello
I've moved into a flat with two light switches in the hall which presumably were intended for two way lighting as they are connected with three core cable . However while the light works fine, both switches need to be in the "on" position for the light to work, so you turn the light off on one switch, the other switch becomes redundant. I've attached a diagram of the wiring. Firstly, is the wiring sound and what would be the reason for this set-up? And if so, is there a way to connect the wiring for two-way lighting?
Thank you in advance!
