Two wire room thermostat for a combi
17 Aug 2004
If I have a combi to install with an onboard timeswitch, as most of them do, I don't really want to install an expensive programmable roomstat. What options do I have for fitting a simple, volt free roomstat? just about everything I look at is 230V
Cheers
Whilst that one would work on a two wire circuit it still has a 240 v anticipater. Use on low voltage would increase the switching temperature differential.
A battery operated programable thermostat has a dif of +- 0.5 degrees and can cost as little as £20. Little point in not using one I would suggest.
Tony
what are the radio frequency stats like to fit and how good do they work when the house has thick stone walls
anyone fitted them
anyone fitted them
They're fine, 30 metre range, not line of sight. Not tried with stone walls though.
